Are Plusnet rebalancing pipes
- Are Plusnet rebalancing pipes
29-10-2009 1:23 PM
Needed to manually disconnect and reconnect to the Plusnet servers to get it working again
Quote Thu, 2009-10-29 13:17:14 - LCP down.
Thu, 2009-10-29 13:17:22 - Initialize LCP.
Thu, 2009-10-29 13:17:22 - LCP is allowed to come up.
Thu, 2009-10-29 13:17:35 - LCP down.
Thu, 2009-10-29 13:17:44 - Initialize LCP.
Thu, 2009-10-29 13:17:44 - LCP is allowed to come up.
Thu, 2009-10-29 13:18:21 - Initialize LCP.
Thu, 2009-10-29 13:18:21 - LCP is allowed to come up.
Thu, 2009-10-29 13:18:24 - CHAP authentication success
Re: Are Plusnet rebalancing pipes
29-10-2009 1:25 PM
29-10-2009 1:37 PM
Please let me know if you see further problems.
29-10-2009 1:41 PM
I was already offline but when I tried to get online at approx 12.40 it kept timing out error 721 unable to connect to remote computer. Rang the help line but recorded message said no problems. Kept getting same error message until a few mins ago then suddenly it's all working again? I'm confused
29-10-2009 1:55 PM
195.166.128.130 ended 13:17 29/Oct/2009 unknown (User request) 81.174.168.118 Not set 06:09 29/Oct/2009 13:17 29/Oct/2009 7:8:29
@rhinocratic, I can see you weren't online at 12:40 but it would be pure speculation if I was to suggest why that might have been!
29-10-2009 2:03 PM
When i noticed the problem the router connection showed Connected to the server but nothing under Negotiation. I tried clicking on Connect which didn't work so I clicked on Disconnect then Connect which did
That bit is probably what the Radius logs picked up
29-10-2009 2:12 PM
Not to worry, Bob. We're back online now
29-10-2009 2:51 PM
29-10-2009 2:58 PM
Now I suppose the next question is whether it is the router or the power supply.
Trouble is I am very happy with the Netgear - it holds on to synch at noise margins down to about 3.5 without too many errors and the bit swapping works properly unlike the last Speedtouch I had
30-10-2009 8:13 AM
30-10-2009 9:21 AM
30-10-2009 9:23 AM
John are you referring to our Thomson routers, or did you mean that you got your Netgear router from somewhere else?
30-10-2009 9:26 AM
