Are Plusnet blocking some news and media sites
Azagoth
I can't open any media or news websites.   For instance, if I try to open the Guardian's site the page just hangs there with "waiting for static.guim.co.uk" displayed.  This happens on nearly all the websites of newspapers.  It looks like something is aggressively blocking the content delivery systems.
9 REPLIES 9
Fixes: 1,483
Re: Are Plusnet' blocking some news and media sites
I can get on the telegraph and guardian ok.
Azagoth
Re: Are Plusnet blocking some news and media sites
Well I can't.  Everything else is working fine, it's just that no news sites will open.
Chris
Legend
Fixes: 169
What results do you get if you trace to the sites? Can't see any issues here that would be causing it.
Oldjim
Resting Legend
Fixes: 63
Which browser are you using and are you using an ad blocking software or security package
According to Adblock Plus it is one of the blockable items
Azagoth
Trace to The Guardian.
Target Name: www.guardian.co.uk
        IP: 77.91.249.30
 Date/Time: 23/05/2011 16:37:24
1    0 ms    0 ms    0 ms    0 ms    0 ms  [192.168.1.1]
2   22 ms   21 ms   22 ms   22 ms   31 ms  lo0.homesurf.thn-ag1.plus.net [195.166.128.102]
3   22 ms   22 ms   22 ms   21 ms   21 ms  gi1-5-706.thn-gw2.plus.net [84.92.5.8]
4   23 ms   55 ms   22 ms   21 ms   21 ms  po4.thn-gw1.plus.net [212.159.1.134]
5   21 ms   26 ms   22 ms   21 ms   21 ms  po6.ptn-gw01.plus.net [212.159.1.137]
6   22 ms   21 ms   22 ms   21 ms   21 ms  po4.ptn-gw02.plus.net [212.159.1.139]
7   22 ms   21 ms   21 ms   20 ms   21 ms  ge-0-2-0-0.lonth-inter-2.interoute.net [195.66.226.53]
8   24 ms   68 ms   32 ms   23 ms   23 ms  [195.81.242.238]
9   23 ms   23 ms   23 ms   22 ms   24 ms  [77.91.255.142]
10   23 ms   22 ms   24 ms   22 ms   23 ms  [77.91.255.146]
11   23 ms   22 ms   23 ms   22 ms   27 ms  [77.91.255.202]
12   *       *       *       *       *       [-]
13   *       *       *       *       *       [-]
14   *       *       *       *       *       [-]
Speed is fine too
Oldjim
Resting Legend
Fixes: 63
I get the same trace result and I can get to it without problems
Tracing route to www.guardian.co.uk [77.91.249.30]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  192.168.0.1
  2    35 ms    35 ms    34 ms  lo0-central1.pcl-ag04.plus.net [195.166.128.241]
  3    35 ms    34 ms    33 ms  gi1-10-411.pcl-gw01.plus.net [84.92.6.224]
  4    34 ms    35 ms    33 ms  te2-2.pte-gw1.plus.net [212.159.0.186]
  5    34 ms    33 ms    34 ms  po4.pte-gw2.plus.net [212.159.1.188]
  6    33 ms    34 ms    34 ms  Gi3-0.lonth-inter-1.interoute.net [195.66.224.53
  7    35 ms    37 ms    45 ms  195.81.242.246
  8    35 ms    36 ms    35 ms  77.91.255.146
  9    35 ms    38 ms    35 ms  77.91.255.202
10    *        *        *    Request timed out.
11    *        *
Chris
Legend
Fixes: 169
Have you checked firewalls, anti-virus software to make sure they aren't blocking the sites?
Might be worth a single reboot of the router to see if that clears the issues.
Azagoth
No firewall, no anti-virus and ad-block plus switched off and they still won't open.  That's in Firefox, Chrome, IE and Safari.
pierre_pierre
no trouble at all with the guardian and now that he has been named in parliament this is on the guardian front page
