Apple TV and iTunes. Frequent disconnections.
- Apple TV and iTunes. Frequent disconnections.
24-05-2011 5:13 PM
My AppleTV frequently disconnects itself from iTunes so I can't sync. The only solution I have found is to turn everything off. Unplug and also turn off the router and start it again. With my previous provider (vodafone) I had no such problems at all. Has anyone else had this issue and if so any ideas as to what may be causing it?
Cheers in advance.
Spec:
Apple TV version 1 - 150GB hard drive (28 gb available)
Software 3.0.2
iMac 2.16Ghz Intel Core Duo 2
Memory 3GB
Mac OSX 10.6.7
iTunes 10.2.2
Router: Thomson TGV585 v8
Software 8.2.7.7.
Cheers in advance.
Spec:
Software 3.0.2
Memory 3GB
Mac OSX 10.6.7
iTunes 10.2.2
Software 8.2.7.7.
Message 1 of 6
(1,340 Views)
5 REPLIES 5
Re: Apple TV and iTunes. Frequent disconnections.
24-05-2011 5:19 PM
Hi ourjon,
If you connect wirelessly I suspect it may be that your firmware version 8.2.7.7 needs updating to the latest 8.2.7.8. I can do this for you but you will be offline for about 10 minutes. Let me know when this is convenient for you.
Jojo
Jojo
Message 2 of 6
(528 Views)
25-06-2011 7:09 PM
Hi Jojo, Thanks for replying. Sorry I haven't got back to you before. Hectic !!
I do connect wirelessly.
The issue still occurs so if you could update the firmware that would be great. Anytime is convenient for me. I can live without the internet for 10 mins....well almost! 😉
I'll check back here to see when its been done.
Thanks in advance.
Jon
Thanks in advance.
Jon
Message 3 of 6
(528 Views)
27-06-2011 3:39 PM
Hi Jon,
I've asked for that to be done for you, so that should take effect soon.
Jojo
Jojo
Message 4 of 6
(528 Views)
27-06-2011 10:26 PM
Awesome! Thankyou Jojo. The software has updated today and i have just clicked on iTunes and lo and behold there is my Apple TV.
Thankyouuuuu
Thankyouuuuu
Message 5 of 6
(528 Views)
28-06-2011 10:54 AM
Ahh, you're welcome, glad it worked
Message 6 of 6
(528 Views)
