Apple Airport Extreme Basestation direct to the BT router? **URGENT**
mattprince
Im just about to go and buy an Apple Airport Extreme Base station to use in place of the Technicolor router. I am right in thinking that i can just connect the apple router direct to the BT router and do away with the technicolor full stop arent i?
The wifi is terrible on the technicolor and was hoping that i could use the apple extreme base station so i have a fast network wifi or not.
Matt
apjashley1
Re: Apple Airport Extreme Basestation direct to the BT router? **URGENT**
Yes, you can.
When you set up the AirPort make sure to choose a "PPPoE" connection, using your username@plusdsl.net and usual password.
mattprince
is my username the same one i log into the plusnet website?
apjashley1
Yes exactly right - but you'll add "@plusdsl.net" to the end of it.
Have you looked at the AirPort Express? It's a bit cheaper, absolutely tiny and has the same wireless capabilities as its big brother
Fixes: 76
Let us know how you get on with this mattprince.
 Adam Walker
1000Cutts
can you confirm what is meant by usual password? wireless password?
The same password you use to log in to your members centre on our website (on www.plus.net where you look after your account etc, not the one for these forums - unless they're the same of course).
