Apple Airport Extreme Basestation direct to the BT router? **URGENT**
- Re: Apple Airport Extreme Basestation direct to th...
02-04-2013 10:38 AM
Im just about to go and buy an Apple Airport Extreme Base station to use in place of the Technicolor router. I am right in thinking that i can just connect the apple router direct to the BT router and do away with the technicolor full stop arent i?
The wifi is terrible on the technicolor and was hoping that i could use the apple extreme base station so i have a fast network wifi or not.
Matt
Matt
Message 1 of 7
(1,878 Views)
6 REPLIES 6
Re: Apple Airport Extreme Basestation direct to the BT router? **URGENT**
02-04-2013 11:35 AM
Yes, you can.
When you set up the AirPort make sure to choose a "PPPoE" connection, using your username@plusdsl.net and usual password.
Message 2 of 7
(594 Views)
02-04-2013 11:52 AM
is my username the same one i log into the plusnet website?
Message 3 of 7
(594 Views)
02-04-2013 11:53 AM
Yes exactly right - but you'll add "@plusdsl.net" to the end of it.
Have you looked at the AirPort Express? It's a bit cheaper, absolutely tiny and has the same wireless capabilities as its big brother
Message 4 of 7
(594 Views)
03-04-2013 10:51 AM
Message 5 of 7
(594 Views)
06-09-2013 1:09 PM
can you confirm what is meant by usual password? wireless password?
Message 6 of 7
(594 Views)
06-09-2013 1:24 PM
The same password you use to log in to your members centre on our website (on www.plus.net where you look after your account etc, not the one for these forums - unless they're the same of course).
Message 7 of 7
(594 Views)
