Appalling download speeds today!
- Appalling download speeds today!
04-11-2007 10:04 AM
Thinkbroadband speedtester reports 500kbps and the BT speedtester shows only 456kbps, despite my IP profile being 7150kbps.
Speeds over the past week or so have been some of the fastest since I joined PlusNet a few years ago, so just not sure what's up.
Anyone got any ideas?
Re: Appalling download speeds today!
04-11-2007 12:33 PM
I realise that BT do not believe a line to be faulty unless it's below 400kbit/s but your line is of sufficient quality for us to be able to push this - let me know if your fault is not raised for this reason and I'll pick it up for you.
Hope this helps,
04-11-2007 1:12 PM
the TBB speedtester really is a waste of bandwidth
04-11-2007 2:23 PM
Thay can often be used together with other tools as a diagnostic aid. By running different ones (and the BT one which BT do rely on) you can get an idea of what/where the problem might be. They are a useful tool no matter how inaccurate they can be at times.
04-11-2007 3:06 PM
04-11-2007 3:10 PM
I've just switched package to BBYW Pro with the default download. I've never exceeded this in all my time with Plus Net so I don't think I'm getting a reduced speed.
I did manage to view my usage but could not make sense of it. It reported 12% VoIP usage!!! What sort of traffic would generate this as I don't use any VoIP services.
Regards David
04-11-2007 5:11 PM
I know all about the offpeak unlimited and I usually stick within these guidelines, but the last few days, even using the service at off peak times, my download speed from newsgroups is abysmal.
Hopefully this is a glitch somewhere and will be cleared up very shortly.
04-11-2007 6:01 PM
163 - 165kbps download
165-195kps - upload
I tried to use the Plus net speed test, dispite disabling norton pop-up blocker and firewall it will not work. I have tried to raise a fault but it points me in the direction of the speed tester. I am on a 2mb account. Can anyone help?
04-11-2007 6:38 PM
Photomad - I suspect this is due to the network being busy, I would suggest changing gateways to see if this helps - this is done by rebooting the connection, you can check which gateway you are on at http://ww.plus.net/@gateway - at present thn-ag1 and thn-ag3 are the least contended.
Delves - Your line profile is showing at 1mb, I'd recommend switching gateways as per the suggestiong above though if you usually get a higher speed try adding filters to all used phone points and testing the connection from the master socket.
Hope that helps,
04-11-2007 8:28 PM
05-11-2007 6:44 AM
Please could you make the adjustments - thanks
05-11-2007 7:07 AM
May not be necessary but cannot do any harm
05-11-2007 7:41 AM
Just to backup the point i made about speedtesters, they both seem to measure about 1/2 my connection according to BW Meter Pro
TBB
Date 05/11/07 07:33:57
Speed Down 2785.68 Kbps ( 2.7 Mbps )
Speed Up 662.87 Kbps ( 0.6 Mbps )
Port 8095
Server speedtest1.adslguide.org.uk
BW Meter Pro states it actually sucked around 350kbps for that
Our very own speedtester
BW meter Pro shows roughly the same.
But a HTTP download from an american server such as Microsoft
Tis truely a strange one to call... and i do get 650kbps now most of the time apart from the odd HTTP server which gets grabbed by Ellacoya
