Anytime I upload something, my internet slows down extremely. What can I do?
- Anytime I upload something, my internet slows down...
13-11-2015 1:17 PM
I'm a new plusnet customer, basically, I'm happy with the PlusNet broadband so far, the only problem is when I upload something, every time when I try to upload any file to my google drive server my internet completely choked up. I speed tested it during this upload and my ping time was around 800ms, download speeds of 0.2Mbit/s and Upload speeds of 0.3Mbit/s. Note, I wasn't downloading anything during this time either. It is just straight upload and wired connected directly to the router.
What is it that causes this phenomenon? Is there anything I could set up to fix this problem(by queues or some such)?
Re: Anytime I upload something, my internet slows down extremely. What can I do?
13-11-2015 1:54 PM
Both up and down speeds are bound to go down and pings up while you are saturating the upload if you perform a speedtest at that time, which will of course affect any other internet activity too.
13-11-2015 3:52 PM
Some previous threads about the same problem:
https://community.plus.net/forum/index.php/topic,142437.msg1257181.html#msg1257181
https://community.plus.net/forum/index.php/topic,143152.0.html
https://community.plus.net/forum/index.php/topic,143682.0.html
https://community.plus.net/forum/index.php/topic,144036.0.html
Not really any solution besides getting another router, or hoping it will be fixed in a future firmware update, which seems very unlikely, because there's lots of things that need fixing, and Plusnet don't seem to care.
13-11-2015 5:10 PM
13-11-2015 5:20 PM
http://community.plus.net/forum/index.php/topic,137629.0.html
14-11-2015 11:47 AM
Quote from: ejs This is a known issue with the Plusnet 2704N router.
I've seen this happen with several different routers, so to point the finger at one device in particular isn't completely correct.
14-11-2015 12:47 PM
How about fixing the problem with the router you supply rather than complaining about people pointing out the problem? Or are you not going to fix the bufferbloat problem, because it affects lots of other routers, so we'll just have to accept the brokenness as normal?
14-11-2015 2:24 PM
14-11-2015 4:04 PM
Phil
14-11-2015 4:11 PM
14-11-2015 6:22 PM
14-11-2015 6:35 PM
14-11-2015 8:32 PM
14-11-2015 9:07 PM
14-11-2015 10:38 PM
