Anyone using Netgear DGND3700v2 or DGND4000?
SoFarSoGood
Fixes: 5
Hi all
Try as I may, many times, I cannot get my Netgear DG834GT to connect to PN.
I've treble plus checked all the settings, password etc.so, by a process of elimination, I guess the DGTeam firmware, or the FW version (DG834GT_V1.03.22_DGTeam_1014_eng_adsldrv023o), is not compatible.
The supplied Technicolor 582n is great as a modem and adequate for my use of wifi but was considering either of the Netgears (see heading) for the extra functions, features etc.so any feedback, good or bad would be appreciated as the 'reviews' online are very mixed.
The 4000 has slightly 'better' wifi specs and VPN (not that than matters too much for me atm) so why pay more for the 3700 v2, unless you prefer Black/Blue to Black/Copper?
Lastly, does it run hot or cold as I can't see any ventilation 'holes' in the pictures I've seen?
Thanks for your help.
46 REPLIES 46
SoFarSoGood
Fixes: 5
Re: Anyone using Netgear DGND3700v2 or DGND4000?
Hi all
I'm pretty sure I have seen a post from someone using the DGND3700v2 but can't find it.
If not using either of the above, any recommendations around the £100 to £120 mark with similar specifications.
In particular, is the modem Bandwidth, throughput speed, stability and uptime as least as good or better than the Technicolor 582n and/or Netgear DG834GT?
Does it run hot or cold and have any ventilation 'holes'?
Any help would be appreciated.
njay
I have previously ran a dg834gt with dgteam firmware on plusnet. Worked really well as I altered the snr ratio down to 60% and still kept in sync. I will see which version of firmware it was as admittedly that was a year ago and I have moved onto a tplink 8960 on ADSL and now fttc.
SoFarSoGood
Fixes: 5
Hi njay
That would be very helpful.
Thank you.
Harro
Hi SoFarSoGood
I had fibre installed today and I am using my Netgear DGND3700v2 (Firmware - V1.1.00.12_1.00.12) and as you can see from my speedtest result, its working good Smiley
hope this helps
Happy Surfing
Keith
HairyMcbiker
All Star
Fixes: 21
I use a 3500v2 with good results.
Bit slow tonight, my upload varies as much as my old adsl used to be!, but the upload climbs.
SoFarSoGood
Fixes: 5
Quote from: Harro
Hi SoFarSoGood
hope this helps
Happy Surfing
Keith
Hi Keith and Hairy Biker
With fibre I believe you are using the BT supplied modem, NOT the Netgear, but thanks anyway.
HairyMcbiker
All Star
Fixes: 21
So the 3700 is a dual router and fibre modem, I didn't know that, but yes I am using the BT modem with my 3500 in-place of the POS supplied.
Fixes: 394
No, but it's got an Ethernet WAN port as well as a normal ADSL RJ11 port. So you can connect it to the BT modem and configure it for pppoe over the WAN port.
SoFarSoGood
Fixes: 5
Quote from: Hairy
Hi Hairy Biker
No, afaik, the 3700 is NOT a fibre modem but can be used as a router connected to a BT modem.
Don't know about the 3500 and presume you are referring to the Technicolor 582n as a POS, and if so, I don't agree.
HairyMcbiker
All Star
Fixes: 21
Well I had TWO of them both with issues, that was why I moved to the 3500. Wired they are adequate, wireless they are useless in a 50yr old house.
Harro
Well, either way im sticking to the 3700v2 as I already had it before I joined PN, Its always been stable and always given good wireless  Cool
SoFarSoGood
Fixes: 5
Quote from: njay
Hi njay
I know I haven't given you much time but would you be able to let me know what FW version you used please?
Would be good to try to get the GT going so I don't have to rush into choosing/buying another modem/router.
Appreciate your help.
njay
Sorry. I didn't get a chance last night  Embarrassed
Will look it up tonight and post back.
BTW was just reading another thread and noticed forum user Sp1ke mentions using a DG834GT with DGTeam firmware so might be worth contacting them too Smiley
njay
FW v1.03.22 dgteam 1018
Network type PPPoA
ADSL firmware A2B023o.d20e
Login ends @plusdsl.net
Idle timeout 0
ADSL settings vcbased 0 38
Advanced ADSL settings
Modulation all except multi mode ticked
SNR 60%
Loop parity inner
Bit swap on
Seamless rate adaption on
All other settings on this page are default.
Hth
