Anyone from Plusnet on here......?
- Anyone from Plusnet on here......?
01-07-2020 7:44 PM
Hi all.
Am having major problems with my broadband and have logged it multiple time but Plusnet keep coming back saying resolved but it isn't. I don't want to leave Plusnet but it's going that way,,,
So here we go:
4 weeks ago router kept rebooting and download speed 0.9MB. Replaced router. No problem on line apparently. Nothing changed - still the same.
Router randomly reboots approximately about 6pm each night and then constantly. Broadband speed is 0.9MB. Impossible to browse any website. Router home page says "DSL Down". Comes back up then goes again.
Again, Plusnet came back with no fault on line and broadband speed normal which it isn't as ran speed test.
Could it be possible neighbours who may be on Plusnet are using up the bandwidth ?
Anyone from Plusnet here to investigate or escalate as this has been ongoing for 4-5 weeks now?
Thanks,
Sq...
Re: Anyone from Plusnet on here......?
01-07-2020 8:22 PM
D/load a free wifi analyser programme, and see which channels most in use in your locale.
Then choose the least used/ unused channel.
Additionally give the 5ghz band a separate name to 2.4 channel.
5ghz is less busy, but has less range within the house.
01-07-2020 8:56 PM
Seems to happen when neighbours get in. One of the other routers SSIDs is a plusnet router. The others are BT HUBS.
01-07-2020 9:33 PM
@Anonymous Can you post your routers statistics page that gives the DSL data - I don't quite know what it comes under on the Hub0.
02-07-2020 9:23 AM
WiFi interference from neighbours wouldn't cause a router to drop the DSL connection. While reported problems are often related to WiFi, this doesn't look like such a problem to me. It is more likely REIN or a faulty router.
02-07-2020 10:12 AM
@corringham I agree, which is why I've asked for the DSL data. It is a good place to start.
26-10-2020 11:17 AM
Hi all - apologies for the delay - been qworking away.
My internet gone again - now for 3 days and cannot connect.
Will post the router dsl data when home later - can this be found on 192.168.1.254/expert_user.html page?
Thanks..
26-10-2020 11:39 AM
In answer to your question about the router statistics, I think so, yes.
