Anyone experienced DNS problems 23rd May 12pm -2pm GMT?
- Re: Anyone experienced DNS problems 23rd May 12pm ...
23-05-2014 2:21 PM
All this through a very stable VNC session through an SSH connection from work...and then suddenly it's all working again.
Was it just me?
You know what a turtle is? Same thing.
Re: Anyone experienced DNS problems 23rd May 12pm -2pm GMT?
23-05-2014 2:21 PM
http://usertools.plus.net/status/archive/1400850987.htm
23-05-2014 2:22 PM
23-05-2014 2:24 PM
23-05-2014 2:29 PM
I've noticed this problem profile a number of times when posting to the forums; all is fine and then for a couple of attempted saves, one gets page cannot be found check URL.
Something is badly broken or configured, because it appears that when this happens access to both DNS servers is lost. I have previously expressed concern about both DNS servers being in the same subnet.
23-05-2014 2:40 PM
I can see why the SSH and VNC connections would be stable, since I established them from the other end so they were using my DNS servers here at work.
23-05-2014 2:41 PM
23-05-2014 2:53 PM
23-05-2014 2:54 PM
Re-booting the router seemed to clear it.
23-05-2014 2:54 PM
23-05-2014 3:03 PM
23-05-2014 3:12 PM
23-05-2014 3:14 PM
23-05-2014 6:37 PM
It coughed again at 18:30.
I see these symptoms nearly daily, particularly when in the forums. I can setup some diagnostic feedback for you if it helps. Just tell me what you need.
Kevin.
