Any suggestiosn for painfully slow internet speed?
- Any suggestiosn for painfully slow internet speed?
10-01-2009 9:22 PM
Although ive raised a ticket, I thought I would still ask the community for ideas.
My connection speed is painfully slow at the moment, it has been for the last few days.
I've 'viewed my usage' and its literllay just peaked 300mb over my allowance, but theres no mention of being penalised for it (which im sure is what doesnt happen on my package?), anyhow, my speed test results are:
which is painfully slow as you can imagine.
Would anyone be able to shed any light on this?
I've also ran connection tests and its returned no faults.
My router is connected at just over 8mb.
Regards
Adam
Regards
Adam
Message 1 of 8
(2,062 Views)
7 REPLIES 7
Re: Any suggestiosn for painfully slow internet speed?
10-01-2009 9:27 PM
OK.
Couple of things... What package are you on firstly, as you may not have had an E-Mail yet about going over your limits.
Can you post your line stats from your router, as you may have had a low sync event
Also can you do a BT speedtest at all, as this will give us your IP profile. What does it say here https://portal.plus.net/my.html?action=data_transfer_speed
If you dont know how to get your line stats, try here.. http://www.kitz.co.uk/routers/index.htm
The above info should give a pointer to where your issues may be...
Message 2 of 8
(610 Views)
10-01-2009 9:47 PM
Thanks for your quick reply penfold.
Rx Sync is 8128
Upstream is constant at around 450
downstream is constant at 8000
Just to clarify, the slow speeds are both from my hardwired PC and my partners wireless laptop.
On average, most webpages (.co.uks and .coms) are taking over 20 seconds to load, this includes plusnets domain.
Quote Telephone number:
01761xxxxxx
Phone exchange:
MIDSOMER NORTON
Estimated line speed:
8 Mbps - Checked on 2008-12-18 09:20:18
Current line speed:
7000
Quote ADSL Link
Downstream
Upstream
Connection Speed
8128 kbps
448 kbps
Line Attenuation
21.0 db
8.5 db
Noise Margin
6.1 db
28.0 db
Rx Sync is 8128
Message 3 of 8
(610 Views)
10-01-2009 9:48 PM
Quote from: Adam1V I've 'viewed my usage' and its literllay just peaked 300mb over my allowance, but theres no mention of being penalised for it (which im sure is what doesnt happen on my package?), anyhow, my speed test results are:
Can you clarify if you have gone over your allowance or not? Which package are you on?
Message 4 of 8
(610 Views)
10-01-2009 9:50 PM
They look OK... Just really need a BT speedtest, to see what your BT profile is, as its just possible you may have had a sync blip, and trashed your BT profile, and what package you are on, as you may be being throttled, if you have gone over your limit.
TBH I suspect it is throttling, by going over your useage limit, but need to know package.
Message 5 of 8
(610 Views)
10-01-2009 9:53 PM
Adie, as I mentioned ive gone 'over my allowance'.
Just spoke to a member of staff. the account was set to restrict instead of carry on and charge. (i cant remember setting this, but its sorted now anyway).
thanks for the help guys.
Message 6 of 8
(610 Views)
10-01-2009 9:54 PM
I thought that was the case, 300MB might be classed as more than 'just gone over'
Glad you have it sorted though
Message 7 of 8
(610 Views)
10-01-2009 9:56 PM
Glad you have found the solution to the problem.
Message 8 of 8
(610 Views)
