Any problems? sites failing to load first time
Currently on pcl-ag05 and I am having a lot of sites fail to load first time, a forced refresh usually fixes it but its happening regularly today.
Iplayer/here/TVcatchup/youtube/twitter
Using Opera 12.16
Network problem
Check that the address is spelled correctly, or try searching for the site.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Fixes: 17
Re: Any problems? sites failing to load first time
cp3547.edgefcs.net (23.62.1.159) and then cp10740.edgefcs.net (23.62.1.156) each failed to start a stream the first time, then worked fine on retrying, but then that just happens sometimes occasionally. Not sure if I can put much significance on it happening twice in a row.
It could have been my router dying, it was getting progressively worse as it went on, eg having to refresh each and every page, trying to post on another forum took 8 attempts/couldn't run speed tests.
They sent me a tester router a while back which I forgot to mail back and using it just now to post this and all seems fine again.  The old TG582n wasn't too hot but will see if this tester gives better results tonight and if so the old one might have a blown cap on it.  Can't open it to find out as the PN sticker on the bottom looks like it could be a warrant void if removed feature and seeing as its free I better not open it as its in warranty.
@ gus
Are you wired or wireless?
Andy, both but the problem was showing on my pc which is wired, my wifi laptop wasn't powered up.  Not had a repeat of the problem since I changed routers, when at its worst ever single site/page/forum I opened all failed to open at least once.
deathtrap
I get some sites randomly doing this, but only if using IE7  FF 22.0 doesn't have this problem, so i would say it's probably down to IE7 and the web page i'm trying to load ,
Fixes: 65
@Gus
I'd agree that sounds like it was just that router, obviously let us know if you see further problems relating to the same thing.
@deathtrap
That may well just be that it's an older version of IE.
 Adam Walker
