Any microfilter recommendations?
Johnmw
The microfilters that came with the plusnet router only seem to be lasting a couple of weeks before my connection becomes very flaky, any recommendations for better quality ones? I'm currently using one i bought cheap off fleabay, i've only been with plusnet since september.
Fixes: 355
Re: Any microfilter recommendations?
If you have the router plugged into the master socket then I'd recommend one of these http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=9881
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Johnmw
Forgot to mention, no master socket
Fixes: 4
+1 for the ADSLNation XTE-2005  Cool
As you are not using the master socket, then I would try these - ADSLNation XF-1e Professional ADSL2+ Microfilter
Johnmw
Thanks, i  think i might order one
Are you having issues with both microfilters we sent, is the one you've bought working OK?
