Any help please?
- Any help please?
Any help please?
19-12-2010 6:48 PM
SERVICE INFORMATION
Close Window
You have been connected to this page due to one of the following reasons. You must now shut down your browser and Internet applications before attempting to reconnect.
•The BTWholesale access circuit to your Service Provider is currently down.
Your service should be resumed soon.
Or
•You are testing your local connection to BT using
‘bt_test_user@startup_domain’
Or
•You are testing your connection to your Service Provider using ‘bt_test_user@domain’ where domain is your Service Provider domain name.
Or
•Your Service Provider is currently unable to accept your connection request please wait until service is restored or contact your Service Provider for further information.
Or
•You have attempted to access an invalid Service Provider domain.
Re: Any help please?
19-12-2010 6:50 PM
19-12-2010 6:52 PM
After going through the "Set Up" options again I always get the same outcome, which is that page.
Thanks for looking
19-12-2010 6:53 PM
19-12-2010 6:54 PM
The first time it was plugged in was yesterday.
19-12-2010 6:59 PM
You can either wait (impatiently ;D) for a rep to turn up tomorrow or call Plusnet and see if they can expedite it,
19-12-2010 7:01 PM
Thanks for the help, hopefully get it sorted soon.
19-12-2010 7:05 PM
19-12-2010 7:06 PM
19-12-2010 7:15 PM
I had my router for 2 weeks before the service was active - it was murder waiting.
19-12-2010 7:45 PM
Only issue I have is that BT page blocking sites.
19-12-2010 7:49 PM
Part of the job is done - this is why you see the broadband light but there is still a bit to do before you can to connect to Plusnet
20-12-2010 9:48 AM
I recieved the modem through the post on Friday the 17th.
20-12-2010 10:04 AM
Your order has now completed and I have performed some maintenance on your account so that you should be able to connect. You need to go into the router and make sure your log in details are correct. These will be:
Username= yourusername@plusdsl.net
Password= your account password (case sensitive)
Any problems then just give us a shout.
Jojo
20-12-2010 10:08 AM
Any problems I'll reply to this shortly.
