Any chance of a reset please?
dc8
Speeds have been declining over the last few days and I am now at approx 120kbps and my router says
  Upstream Downstream
Current Rate(kbps) 928 1152
Max Rate(kbps) 1080 3464
SNR Margin(dB) 7 18.7
Line Attenuation(dB) 31.5 55
Errors(pkts) 168 3
Any chance of a reset please to get some sort of useable speed back?
Thanks in advance.
7 REPLIES 7
MMG
Re: Any chance of a reset please?
Have you got any extension sockets on your socket?
If so then I would remove the faceplate on the master socket, remove any extension sockets and plug your modem and router into the "test" socket if possible.
See what your speed is there.
This eliminates any issues with your internal wiring
dc8
No extension leads they were all disconnected last time I had problems.
The latest BT Master socket was also installed by the engineers after they sorted a problem out at a roadside box between me and the exchange and I run directly from that to my router (with the faceplate).
Nothing has changed here apart from the weather recently and as things are not great here at the best of times as you will probably see from my normal "best" connection speed ALL that is needed is a reset at the exchange.
The recent wind and rain is almost certainly the issue.
Currently router shows
  Upstream Downstream
Max Rate(kbps) 1080 3452
SNR Margin(dB) 7 18.6
Errors(pkts) 177 4
Aspiring Legend
Fixes: 196
@dc8 Just out of interest, do you happen to know your 'normal' downstream SNR? the above looks a little high, to me.
dc8
About normal for here 😬
Aspiring Legend
Fixes: 196
@dc8  OK .😉
dc8
Is there anyone from plusnet going to do a reset or are you just going to ignore things?
Fixes: 1,551
Thanks for getting in touch @dc8 and apologies for the delayed staff response. I'm sorry to see you're experiencing speed problems. I've tested your line today and the tests aren't showing any causes for this so I've removed the 576-1152kbps banding now and upon retesting I can see your router's now getting a speed of 3.4mbps.
If you have further issues with this, I'd recommend raising a speed fault online at faults.plus.net. It's worth noting that together with our network partners at Openreach we are prioritising customers who don’t have a phone line or broadband connection, meaning there might be a delay in speed faults being fixed.
[edit]
As a heads up a normal downstream SNRM is 6dB. It was 18.6dB because the line was banded. Smiley
