Anti Virus Mk2
jono
Anti Virus Mk2
Hi I think I made a mess of posting previous question, could anyone tell if the Antivirus within My account area is free, its disabled at the moment, would it be worth switching on if I'm only going to use Office Outlook, i run Norton Internet security 2008 as well, I dont migrate fully untill 30th.
regards
jono
Fixes: 74
Re: Anti Virus Mk2
Yes, it's free.
You should always run a client side antivirus application as well though as the only thing our virus filter will scan is your incoming PlusNet email.
Plusnet Products Team
jono
Re: Anti Virus Mk2
Thanks, i shall enable then.
regards
jono
