Anti Spoofing measures
- Re: Anti Spoofing measures
14-08-2018 2:25 PM
We are a community store, recently moved to Plusnet for faster broadband to enable our card machine to take payments using our internet connection rather than the phone line.
I am completed our PCI DSS compliance questionnaire and need to know if there are anti-spoofing meaures in place on the Plusnet router?
This is to detect and block forged sourced IP addresses from entering the network.
It is critical to our PCI DSS compliance, which is already overdue.
If there are no measures in place, what can we do instead? Can we use a different router (with anti spoofing measures) and still have our contract with Plusnet?
Thank you!
14-08-2018 2:59 PM
I believe the same question has been asked before https://community.plus.net/t5/Broadband/Anti-spoofing-on-router/td-p/1422512
As indicated in that thread , you will need to use a different router to provide those facilities.
Hope that helps
14-08-2018 3:01 PM
Thank you. I saw that thread but as it was from last year, thought I would start a new one in case the situation had changed.
I've managed to speak to someone in the Plusnet business team on this matter today. They've advised that the router does prevent spoofing, but isn't "officially" anti-spoofing compliant for some of the card machine providers, so it depends what question they ask on this matter and whether the cost of non-compliance here is less than the cost of introducing a new router which officially ticks the boxes.
14-08-2018 3:15 PM - edited 14-08-2018 3:21 PM
If it helps, then something like a Draytek 2862 , which has the anti-spoofing facility and is ADSL/VDSL compatible will cost between £185 & £230 depending on whether you need wireless or not https://www.broadbandbuyer.com/store/fibre-routers/bt-infinity-routers/ .
14-08-2018 3:19 PM
Thank you, much appreciated.
14-08-2018 3:22 PM
@ewelmestore actually if you don't need the performance of the 2862 or the VPN capability
then from what I can see the 2762 also has the anti-spoofing ( BLOCK land ) option on it's firewall settings and is £125
https://www.broadbandbuyer.com/products/31965-draytek-v2762n-k/
