Answer Machine interfering with connection
- Answer Machine interfering with connection
18-10-2013 1:20 PM
we have just bought an answer machine and plugged it into the telephone socket using a dual adaptor, the microfilter and phone are in the other one. That has affected the broadband connection. Does anyone have any idea what to do or if it's not possible to use an answer phone and broadband.
Message 1 of 6
(1,067 Views)
5 REPLIES 5
Re: Answer Machine interfering with connection
18-10-2013 1:25 PM
Is the answer machine going straight into a phone socket or does it go through a micro filter?
As far as I am aware, any device plugged into any phone socket needs to have the micro filter plugged in first. This should sort the problem.
Message 2 of 6
(563 Views)
18-10-2013 1:45 PM
Yes, you need to change so that the microfilter is plugged directly into the telephone socket and the dual adapter is then plugged into the phone port on the microfilter. Then plug the phone and the answer machine into the dual adapter. That way both the phone and answer m/c will be filtered.
Message 3 of 6
(563 Views)
18-10-2013 2:00 PM
If the dual adapter doesn't fit on your microfilter (if, for example it obscures the router port) then you could install a second microfilter (for the answer machine) into the dual adapter, the critical thing being that all telephone equipment (telephones, DECT base stations, answering machines, caller display units, fax machines, sky boxes etc.) connected to the telephone line MUST go via a microfilter.
Call me 'w23'
Message 4 of 6
(563 Views)
18-10-2013 3:20 PM
Thank you very much, the adaptor doesn't fit into the microfilter so I will get another one and that should sort it.
Message 5 of 6
(563 Views)
18-10-2013 4:18 PM
If you have a telephone extension lead you could put that between the filter and the dual adapter.
Message 6 of 6
(563 Views)
