Another stuck profile
- Re: Another stuck profile
18-05-2008 1:11 PM
Since the explosion at a Chelmsford electricity sub-station a week and a half ago, my "connection settings" on the portal has said the following
My Account
Your High-speed Broadband Service
Your current broadband speed is 500 Kbps
My router has been back to syncing at around 5000 - 5500 Kbps for almost all of that time. How can I get this back to where it should be please?
I've tried turning the router off overnight, to force a reconnection.
My Account
Message 1 of 8
(1,578 Views)
7 REPLIES 7
18-05-2008 2:01 PM
What does the BT speedtester say your IP Profile is?
Getting that to run can be difficult but I've just succeeded (at my first attempt too).
David
Message 2 of 8
(501 Views)
18-05-2008 8:58 PM
I get as far as:
"The Performance Tester is now testing Broadband connection. Your configured download throughput speed for this service is 4500 k
Please do not move away from this page and do not start any other download activity on your computer."
and progress at 96%, then it hangs.
Does this help?
Does this help?
Message 3 of 8
(501 Views)
18-05-2008 9:01 PM
That's about right as a profile for your sync speeds.
Message 4 of 8
(501 Views)
18-05-2008 9:10 PM
I get as far as:
I have had this several times lately..... I think it must be overloaded.....
close the page, and then you just have to wait for about 15 minutes, and try again.....
Message 5 of 8
(501 Views)
18-05-2008 9:26 PM
Quote from: HPsauce That's about right as a profile for your sync speeds.
I agree, but as the original post says, according to the portal my "current broadband speed is 500Kbps", so my router is syncing at around 5500 Kbps. BT thinks I should be operating at around 4500Kbps, but Plusnet is actually running my connection at 500Kbps
Message 6 of 8
(501 Views)
18-05-2008 9:34 PM
Ask PN to fix it, they can do that easily when there's a mismatch.
Message 7 of 8
(501 Views)
19-05-2008 12:27 PM
Hulls,
I've just updated your line profile for you. Can you please disconnect and reconnect and all should be fine.
Message 8 of 8
(501 Views)
