Another speed moan
- Another speed moan
- « Previous
- 1
- 2
- Next »
Re: Another speed moan
08-12-2009 12:23 PM
I should add that the above speed was before I put the other filter in, I've just installed it & will power down the router now. Noise seems to have settled on 6db for now. I'm on a Mac so that link won't work, will have a search around for something simliar. Cheers.
Message 16 of 19
(285 Views)
08-12-2009 5:39 PM
Ok, filter is in. As expected the speed has dropped to 600kb/s as per usual, connection has dropped a couple of times, and noise margin is now hovering between 0-1db (I know you said any improvement would take a while though). What's puzzling now is that I found on the router stats site an option to track in the browser and these are the results compared to what my router is telling me. Which should I trust?
Message 17 of 19
(285 Views)
08-12-2009 5:48 PM
Routerstats calculates noise margin differently to the router although there isn't usually a big difference
Message 18 of 19
(285 Views)
08-12-2009 6:16 PM
I've just spotted something. You are not running an up to date version of the firmware for your Netgear router - that could be why we are seeing some funny figures reported. Can you get the latest firmware to see if that makes a difference please.
Message 19 of 19
(285 Views)
- « Previous
- 1
- 2
- Next »
