Another speed drop - 21st November
- Another speed drop - 21st November
27-11-2007 3:34 PM
My logs:
22-11-2007 12:37:20 479.9
22-11-2007 11:59:27 480.1
22-11-2007 11:59:03 426.8
22-11-2007 11:43:18 477.9
21-11-2007 15:55:49 480.5
21-11-2007 15:55:20 497.5
20-11-2007 16:27:41 956.4
20-11-2007 16:27:09 954.5
20-11-2007 16:26:30 954.9
20-11-2007 16:25:59 938.3
24-10-2007 17:13:23 702.3
24-10-2007 17:13:00 700.6
24-10-2007 17:12:36 714.4
27-09-2007 13:48:33 702.3
27-09-2007 13:48:10 678
25-09-2007 09:17:24 717
Something happened on the 20/21st November. No change this end in equipment, had the same router for about 2 years. All cabled up, no trojans - swept the PCs for viruses/trojans etc.
My router is saying: 448 Kbps Upstream, 1152 Kbps Downstream - I think the Downstream had jumped to around the 1450 mark with the initial jump in the speed tests on the 20th November, but I can't remember. Any clues?
Re: Another speed drop - 21st November
27-11-2007 3:35 PM
If you see my other reply to your other post, I have suggested that you reboot your router as I feel that this should result in your seeing improved speeds.
27-11-2007 3:45 PM
27-11-2007 3:50 PM
You seriously are a dude! Cheers
14-12-2007 12:51 PM
14-12-2007 1:04 PM
you should be back upto 1000Kbps now, so if you give your router a reboot, speeds should be back up.
14-12-2007 4:03 PM
Yup, thanks, it's back up What's happening with it, is it something I can stop happening?
14-12-2007 4:10 PM
It was just a little sync blip, which does happen with Max every so often.
You can always try changing filters and ensuring that you're connected to your master socket via a filter, there isn't really that much else you can do.
16-12-2007 8:56 PM
30-12-2007 10:12 AM
Much appreciated!
And hope you had a Merry Christmas
02-01-2008 2:51 PM
Your profile is currently set to 750Kbps in line with your synchronisation speed. I've treated things slightly at this end, so if you reboot your router, you should notice a slight improvement.
02-01-2008 5:28 PM
Sometime this year we'll be swapping our plus.net account to another number in the house (and therefore line) so maybe that will be better - it's a bit newer than the current one but it has no built-in filter so maybe I can experiment with the filters then.
02-01-2008 5:35 PM
If you hold onto that sync speed, then you should go back onto the 1Mbps profile. You'll have had a recent blip, causing the sync speed to drop hence the change in profile.
