I’ve been using my Sky Router for a couple of years, but am trying now to upgrade.
I’m on ADSL, I’ve a Linksys MR8300 router, and a Draytek Vigor 130 Ethernet modem connected to it via an Ethernet cable, and cannot get them to work.
In theory the Plusnet settings (username, password etc) should be entered into the Linksys unit, Not the modem, as the Modem works in “Bridge” mode, and just passes these on, but despite having updated everything to match it just doesn’t connect to Plusnet.
There’s a lovely strong WiFi network, the modem is connected into the master socket where the service enters my house (and which has been working up until now, and still is if I plug my Sky Router back in), but when I get on that network, it simply doesn’t connect to your service.
Are you able to re-confirm which settings I need to put into the Router, and let me know if it sounds as though I am doing anything wrong?
The sky router’s back attached are the moment, so ai can send this.
