Another great day for speed on PlusNet.
- Another great day for speed on PlusNet.
19-10-2011 12:59 AM
Message 1 of 4
(776 Views)
3 REPLIES 3
Re: Another great day for speed on PlusNet.
19-10-2011 8:49 AM
You could give our faults team a call or raise a fault for us to investigate.
I've taken a quick look over your account and can't see anything obvious, everything appears as it should and you should be getting near 5Mb speeds. I see you've been connected for 7 days straight, can you try a single reboot of your router then perform another speedtest to see if it improves.
Message 2 of 4
(388 Views)
19-10-2011 8:54 AM
I am only getting a download speed of 2336 and an upload speed of 349 Kbps. My neighbour who is with TalkTalk gets 3565 and 680.
We obviously live the same distance from the telephone exchange and our houses are fed from the same telegraph pole. Why the difference in speeds? Not happy!
Message 3 of 4
(388 Views)
19-10-2011 9:02 AM
welcome to the Forum
its because TT - that dreaded lot dont use the BT equipment in the exchange
Message 4 of 4
(388 Views)
