Another customer with ridiculously low speeds..
- Another customer with ridiculously low speeds..
Re: Another customer with ridiculously low speeds..
05-02-2013 11:33 PM
I was predicted 62Mbps down and 14Mbps up. My last speedtest kind of speaks for itself.
http://speedtest.net/result/2485264368.png
Obviously there are some extenuating circumstances in your case but to carry on the way wouldn't make me want to help you much. It does appear that the plusnet staffers around here are made of better stuff than me
05-02-2013 11:58 PM
Quote from: Bright ... the BTW Broadband Availability Checker site, which can tell you what your line should be capable of on each type of service, should know whether you have copper or aluminium cable and factor that into the results.
Well yes, in an ideal world it should take the type of cable into account but does it really try to do this? I rather doubt that.
06-02-2013 10:55 AM
Quote from: ReedRichards
But then again BTOR do have the capabilities to see or at least check where they may have a problem area (aluminium cabling) the 3rd and 4th engineer told me that, that sort of cable was not designed for this generation of technology, with this in mind they should at least sort of know what they are talking about, IMHO for the property i live in it is all about trying to raise as much cash above QoS, why should i or anyone for that matter move then be told to put up or shut up but give us your cash (sorry for the abruptness no harm intended) no one should that is bullying, every little helps i do appreciate, very very much what Plusnet staff are trying to do for this case. Which is they are working tirelessly trying to get me a better service but Openreach won't budge it looks like, it is starting to look very much like i have no other option in this case but to go back to ADSL2+ (which is a sad state of affairs) and save our money as we are below the acceptable standard level for FTTC which is 15MB download and no idea about what is deemed acceptable levels for upload
Thankyou a frustrated customer.
P.S Pengbo i am so pleased you are happy with your connection that is a compliment to you and plusnets great work...
06-02-2013 11:46 AM
Question: What speed were you getting on ADSL2+? Sorry if you've already said this somewhere in the thread, but I can't see it if you have.
Also, do any of your immediate neighbours have FTTC broadband? If so, what speeds do they get? They should be similar to yours, assuming they are also on an 80/20 package (even if they are on 40/10 that would indicate if they are getting higher throughput than you).
From what you have posted here over the past 2+ weeks, it seems that the speed of your line has been going up and down like a yo-yo:
- 1.6 down and 3.3 up on 18 Jan,
- 17 down and 2.5 up later that day
- 15 down and 1.2 up on 24 Jan
- 21 down and 1.5 up on 26 Jan
- 19 down and 1.2 up on 27 Jan
- 15 down and 1.2 up on 1 Feb
- 14 down and 1.2 up on 2 Feb
- 12 down and 1.2 up on 3 Feb
- 11 down and 1.2 up on 4 Feb
Assuming all these measurements were taken using a PC connected to the router by an ethernet cable (and not over a wifi connection), they don't exactly suggest you have a stable line! Whether you're connected by copper or aluminium or wet string, the line shouldn't be going up and down in throughput like this. Also on 18 Jan, Adam from Plusnet pointed out that your line was suffering regular disconnections:
http://community.plus.net/forum/index.php/topic,110982.msg951575.html#msg951575
So despite visits from 5 (?) BTOR engineers, it looks like your line has a fault which they haven't got to the bottom of yet. Rather than starting a petition, I'd be chasing Plusnet to escalate this problem!
06-02-2013 11:00 PM
07-02-2013 2:19 AM
Also, distance from the DP is not really relevant. On ADSL it the distance from the exchange that's important. On Fibre it the distance from the Cab (PCP) that's important.
Put your phone number into https://www.dslchecker.bt.com/pls/adsl/adslchecker.welcome and it should tell you which Cab you are connected to.
Go and find it and see how far away you are from it using the route the cable would go.
07-02-2013 8:07 AM
07-02-2013 8:22 AM
I have done this for mine and when you look at a group of post codes the cabinet is invariably towards the side of the group of post codes nearest the exchange on a main road. At least they are by me. You can then go look to see if the cab has a number on it. Unfortunately quite a lot don't
07-02-2013 8:56 AM
07-02-2013 1:19 PM
Whilst Aluminium doesn't perform as well as Copper, it shouldn't be as bad as you are seeing, I suspect the cable is faulty.
07-02-2013 5:22 PM
Sorry to see that you're still having problems with this. FYI the connection is looking a little more stable than when I first looked at your issue but is still dropping fairly frequently.
Sorry too to read about the issues with some of the engineer visits. I'm going to pick through those in more detail tomorrow to make sure that's all fed back to our suppliers.
IMHO we definitely need to work on escalating this issue before even considering another engineer visit so I'll do my best to catch up with my colleague in faults (DG) tomorrow morning to make sure we have a plan in place for that.
Adam
07-02-2013 6:23 PM
08-02-2013 10:09 PM
[url=http://www.thinkbroadband.com/ping/share/eb8702c6495c679761f45b077859531a-08-02-2013.html][
08-02-2013 10:44 PM
Do you know if you had a drop in connection around 9.00pm? Are you on a fixed IP address or a Dynamic one?
I suggest you ask Plusnet to post up your latest Connection chart (Visual Radius) which will give an idea how stable you connection has been.
It does look like a number of users will have had a drop in PPP session just before 9.00pm as seen here probably due to this
Edit: add links
08-02-2013 11:51 PM
You are currently connected to the gateway known as ptn-ag01.
This is located in Telehouse North.
Yes it dropped off @ 9pm and 10.40pm
