Another constant internet drop thread
- Another constant internet drop thread
Re: Connection dropout
03-08-2014 10:58 PM
04-08-2014 9:42 AM
04-08-2014 9:48 AM
Re: Another constant internet drop thread
04-08-2014 9:51 AM
04-08-2014 10:35 AM
I've just taken a look through your connection logs and while there doesn't appear to be a strong pattern, there are a disconnections which line up roughly over the course of the last week which could indicate something electrical being turned on or used that causes interference and a drop in service.
This is a tough one to diagnose as it could be both internal or external to your address so it may not be immediately evident. In addition to this I have also taken a look at your line and the stats all seem to be fine with no faults found.
If you could post your router stats as Jim outlined we should be able to investigate a little further.
EDIT
Sorry, I should have posted this earlier -
<img src="http://community.plus.net/visualradius/generated/image14071465191008.png"/>
04-08-2014 10:39 AM
Link Information
Uptime: 0 days, 8:50:56
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,816
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 8.5 / 17.0
SN Margin (Up/Down) [dB]: 21.0 / 10.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 509 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 15,949
HEC Errors (Up/Down): 0 / 3,634
04-08-2014 11:19 AM
Can you please revisit my advice from April and post a full set of stats?
@DCT,
Can we have a radius graph please to see if there are any patterns to these disconnects?
Thanks,
Kevin
04-08-2014 11:44 AM
6.26 down
0.36 up
38.50ms latency
Further diagnostics:
Best Effort Test: -provides background information.
Download Speed
6.26 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 6.26 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :6.82 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 5.5 Mbps
Also looking at that graph it doesnt show multiple disconnects? i must of disconnected about 30 times instant on/off last night
04-08-2014 12:08 PM
What did you see which made you think you were disconnected? Could it be that your PC is reporting a WIRELESS disconnection, which would be quite a different matter?
You are seeing some ADSL disconnections, the ADSL service is not as good as might be expected for your line (as I said in April), but the identifiable evidence does not match your perceived experience. Did you ease a fault here http://faults.plus.net back in April? If yes, what was the outcome?
@DCT,
Has a full copper test been run on this circuit either back in April or more recently? If yes what does it report?
Something is amiss here, this appears to be fast path (no FEC errors), there is plenty of SNRM headroom, the line is short, but the synch speed is way short of the maximum fir 20CN ADSL. I'm assuming that 21CN is not available on this exchange?
Kevin
04-08-2014 12:23 PM
I did raise a fault, they reset my line and all that jazz to try get the speed higher but nothing changed. I went on holiday and totally forgot to report back to the fault and it was closed. Thing is although my speed isnt what it should be its decent enough for me, its more thus disconnecting thing in the evening thats the pain... but if i can get my line faster that would be handy to!
04-08-2014 1:25 PM
I've just received your initial testing back on the faults check and there doesn't seem to be anything showing that's out of the ordinary although the testing is having difficulty establishing a PPP session. From your mention of the router dropping all lights and just showing power until it reboots I'm wondering if this could be an issue being caused by the router, have you had this swapped out or tested with another piece of hardware?
04-08-2014 2:24 PM
The symptoms reported by the user are not reflected in the radius log reports of lost PPP sessions. Something is not stacking up here. There have been suggestions around which suggests that PPP sessions can sometimes survive synch losses - not really sure I'm convinced - but that is the only explanation which matches the user's reported experience and the PN radius report.
What does the BTOR connectivity history report?
@KaotiK,
When this happens next, can you please go and look at the router log BEFORE doing anything else. Also try the check connectivity test in the router.
I'm interested in finding out if the router has done a warm restart and / or what level of connectivity failure the router thinks is present. I'm aware that intermittent DNS problems can give the impression of a disconnection.
This looks like a very strange / unusual issue - in 99% of situations you are describing the radius log report provided by Adam would be strewn with disconnection indicators. It is not - so something out of the ordinary is taking place here. If the router logs do not show anything, I think we will need to ask you to down load inSSIDer and RouterStats to gather more information. We'll cross that bridge when we have to.
Kevin
04-08-2014 4:04 PM
04-08-2014 10:29 PM
05-08-2014 10:44 AM
