Another Speed Problem
- Re: Another Speed Problem
29-01-2008 11:36 AM
Syncspeed seems to be stuck at 2000k
Latest BT Spped test :
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 2000 kbps
DSL connection rate: 832 kbps(UP-STREAM) 2976 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1460 kbps
Download speed varies between 1900 & 3100 kbps
I've changed routers & Microfilters. I've plugged directly into master socket.
Everything is switched off every night, anything else i can try ?
Thanks - DM
Thanks - DM
Message 1 of 9
(2,251 Views)
8 REPLIES 8
29-01-2008 11:41 AM
You should see your profile rise to 2500Kbps in the next days or so.
To be realistic though, this will fluctuate. It's the way that Max often behaves. You will often see different sync/connection speeds when you reconnect to the internet, subsequently causing different profiled speds.
Link:SPeed
Link:SPeed
Message 2 of 9
(880 Views)
29-01-2008 11:45 AM
Thanks for very speedy response.........
Message 3 of 9
(880 Views)
05-02-2008 9:11 AM
I've given it a week and not seen much difference.
DSL connection rate: 832 kbps(UP-STREAM) 3424 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1820 kbps
Is there anything else that can be done ?
Message 4 of 9
(880 Views)
05-02-2008 9:16 AM
Have a read of the broadband speed faults how to diagnose
link James gave for starters.
Message 5 of 9
(880 Views)
05-02-2008 9:31 AM
Thanks, but i did that before posting original message.
Message 6 of 9
(880 Views)
05-02-2008 10:28 AM
BT bumped up your profile at roughly 10am today.
If you reboot your router you should see the improved performance.
Message 7 of 9
(880 Views)
05-02-2008 10:47 AM
Seems to be improving, many thanks.
Message 8 of 9
(880 Views)
05-02-2008 1:38 PM
Big improvement.
IP profile for your line is - 2500 kbps
DSL connection rate: 832 kbps(UP-STREAM) 3072 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 2314 kbps
Many thanks
DM
Many thanks
DM
Message 9 of 9
(880 Views)
