Another Fibre router question
Timalay
After it seems my original new fibre router I bought for myself seemed faulty.  I am now on the hunt for another, so far I've seen the Linksys EA6400, am I right in thinking this will work with Plusnet's Fibre broadband?
Timalay
Re: Another Fibre router question
Anybody?
Is it just a fibre router you need without the modem?
I use a Netgear N750, it is a bit pricier than a lot of equipment out there but it is a fantastic router!
