Another Airport Extreme connection problem
- Another Airport Extreme connection problem
- « Previous
- Next »
Re: Another Airport Extreme connection problem
05-06-2014 4:36 PM
Hi again Daniel,
Upon further inspection of the account it looks like the agent who manually enabled this has missed the stage where the realm is added and configured. This means the account appeared active and the broadband order showed as complete however the connection couldn't be established on the authentication side due to the missing component.
This has now been picked up and manually added/configured so you will no doubt see the connection spring to life shortly so let us know how you get on!
Apologies for missing this in the initial instance and big thanks to pwatson for prompting a deeper investigation into activation logs of the account
Message 31 of 36
(566 Views)
05-06-2014 4:40 PM
Hurrah,
Okay thank you very much Acassim. I will double check when I get home.
At least the Mrs will be happy now she has iPlayer back!
I will report back later
Message 32 of 36
(566 Views)
05-06-2014 4:44 PM
Fingers crossed!
I've been checking the connection logs and haven't seen any connection attempts just yet, is the modem/router plugged in and powered up with the correct login details in it at the moment?
I'll also arrange for a good will gesture to be added to your account as this was clearly a mix up from one of our agents, you should see details of this pop up on your support ticket shortly.
Thanks,
Adam C
Thanks,
Adam C
Message 33 of 36
(566 Views)
05-06-2014 5:00 PM
Forgive me for jumping in but I didn't think that the modem had the login details just the router
Message 34 of 36
(566 Views)
05-06-2014 5:02 PM
Apologies Jim,
Edited now and should be a little clearer.
Thanks,
Adam C
Thanks,
Adam C
Message 35 of 36
(566 Views)
05-06-2014 7:09 PM
I would like to thank everyone who helped me with this.
I have now successfully connected to the internet!
Thanks once again.
Thanks once again.
Message 36 of 36
(566 Views)
- « Previous
- Next »
