Anonimous IP
- Re: Anonimous IP
Anonimous IP
31-03-2016 5:31 PM
I am having a problem with one website; royalgames.com
I keep getting; 'login blocked'.
I made a query with their IT people and have been informed that I am using some kind of 'anonimiser'.
As I can access any other site I wish to go to, I assume I am showing my IP. But, I am not showing it to this site.
Can I get into the router and ensure that I am always showing my IP, or is there some other way of doing this?
Otherwise, I believe there must be some kind of error in their software. Explaining that, will not be easy.
Message 1 of 7
(862 Views)
6 REPLIES 6
Re: Anonimous IP
31-03-2016 6:13 PM
goto google.co.uk and enter "whats my ip" as a search
that will show you your external ip address that is sent to web sites.
Message 2 of 7
(654 Views)
Re: Anonimous IP
31-03-2016 6:30 PM
Thanks hairy, but that doesn't answer the question.
I am no wiser.
I am no wiser.
Message 3 of 7
(654 Views)
Re: Anonimous IP
31-03-2016 6:32 PM
Message 4 of 7
(654 Views)
Re: Anonimous IP
31-03-2016 6:44 PM
You asked what your external ip was, it is always shown to sites unless you are visiting via a proxy.
Nothing in your router setup will change this.
Message 5 of 7
(654 Views)
Re: Anonimous IP
31-03-2016 9:27 PM
Are you using Google Chrome on a Google android device (eg Nexus 7)? That sends HTTP requests via a compression proxy. The headers include "Forwarded For" which supplies the real IP, but the receiving end would have to do a special check for that.
David
Message 6 of 7
(654 Views)
Re: Anonimous IP
31-03-2016 10:27 PM
Try disconnecting/reconnecting. Someone who previously had your IP might have been using it as a ToR exit node or similar.
Message 7 of 7
(654 Views)
