Am I stuck with 4000mb?
- Am I stuck with 4000mb?
Re: Am I stuck with 4000mb?
28-09-2011 8:42 PM
Quote Am I stuck with 4000mb?
Lucky you, even users on FTTP can only get 100mbps maximum!
29-09-2011 10:21 AM
@ Jelv I agree I wondered how long it would be before some bright spark made a comment like that.
Nice sky dancer btw.
29-09-2011 10:23 AM
I'll take a look at that for you and confirm back when it's done.
Jojo
29-09-2011 10:42 AM
04-10-2011 3:41 PM
04-10-2011 5:07 PM
The BT IP Profile does reflect the maximum download speed the line could achieve, and that will be either 88.2% of sync speed or a multiple of 500 below that (for what I assume is your sync speed) depending on whether the quantisation update is on your MSAN.
The Plusnet Current line speed will presently be a 500 multiple, and if that is significantly below the BT IP Profile it will need Plusnet to set it manually to remove that cap on your download speed.
05-10-2011 10:51 AM
It'll depend on your sync rate but your connection's not banded any more. Both profiles (ours and BTs) are matching at 3500 at present. If you get a different profile reported following a BT speed test (http://www.speedtester.bt.com) let us know and we'll make sure your PN profile is set to match.
02-11-2011 6:18 PM
Download speed achieved during the test was - 3106 Kbps
For your connection, the acceptable range of speeds is 2000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :6269 Kbps(DOWN-STREAM), 439 Kbps(UP-STREAM)
IP Profile for your line is - 5530 Kbps
Router results:
SNR Margin 9 23 dB
Line Attenuation 38 22 dB
Data Rate 6269 439 kbps
But I'm still seeing a current line speed: 3.5 Mb in my connection settings. It's been like that for a couple of weeks now.
03-11-2011 9:10 AM
A sync check shows you currently in sync at around 6600, though the latest profile update on the delta report side shows the latest recorded sync at 4000 so you're still on the 3500 profile at the moment. Unfortunately upping the profile on our side would make no change as things stand.
I've done a consistency check test too to make sure your profile's not showing any different at the exchange, and it's not so there's no fault there either.
The best thing given that you are in sync above that would probably be to resync the router once a day round lunchtime (best done by disconnecting from the broadband via the router's interface before powering it off and on again) as that should lead to the exchange recording the improved speed and upping the profile to match.
Hope that helps,
03-11-2011 9:33 AM
03-11-2011 9:38 AM
03-11-2011 11:35 AM
03-11-2011 11:42 AM
03-11-2011 4:17 PM
I suspect though that rebooting the router from the interface would cause the connection to be dropped correctly though so that will probably save time all round Must admit though I'm not 100% certain of that.
03-11-2011 4:28 PM
Quote I suspect though that rebooting the router from the interface would cause the connection to be dropped correctly though so that will probably save time all round Must admit though I'm not 100% certain of that.
Matt it works, below is a sample of disconnect followed by a "restart of The Thomson Router" all done through the webpage
To be is to do - Kant
do be do be do - Sinatra
