Am I on an ADSL2+ exchange?
- Am I on an ADSL2+ exchange?
06-12-2011 4:39 PM
Checking Samknows it gives a date of 31'st December (not far away) but I checked BT and it said:
"Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 5Mbps; typically the line speed would range between 3Mbps and 7.5Mbps. Our test also indicates that your line could support an estimated ADSL 2+ Annex-M broadband upstream line speed of 1Mbps and downstream line speed of 5Mbps; typically the downstream speed would range between 3Mbps and 7.5Mbps."
So I'm wondering if I actually can get ADSL2 now and if so, how do I get it switched on? If I can't get it, is the 31st Dec date correct?
/edit Hayle exchange Sam Knows
Message 1 of 9
(1,727 Views)
8 REPLIES 8
Re: Am I on an ADSL2+ exchange?
06-12-2011 5:50 PM
with your apparent current low download, I doubt if you would get much from ADSL2+, but I see that you are also due to get Fibre on the same date, that would be much more benificial, but cost more.
Give my love to G J Beads, one of these days I will get to their warehouse
Message 2 of 9
(825 Views)
06-12-2011 6:03 PM
I'd ignore the estimated speeds, I should get 16Mb+. Fibre (FTTP too!) isn't due till end of 2012.
Current line stats:
Currently connected at 8128 but if I stick in a different router it'll drop to 29 or so, so maybe my router is mis-reporting my attenuation, dunno.
Current line stats:
Quote Alcatel 20190 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT) Annex A
ITU STD NUM: 0x03 0x2
Vendor ID: 'STMI' 'TSTC'
Vendor Specific: 0x0000 0x0000
Vendor Country: 0x0F 0xB5
Chip ID: C196 (0)
DFE BOM: DFE3.0 Annex A (1)
Capacity Used: 96% 64%
Noise Margin: 5.5 dB 17.0 dB
Output Power: 18.5 dBm 12.5 dBm
Attenuation: 33.5 dB 15.5 dB
Message 3 of 9
(825 Views)
06-12-2011 6:47 PM
I think "currently supports ... ADSL2+" means it is available now; it would say "could support" if it wasn't. When my exchange was enabled the estimated date was the end of the month but I was able to request it mid month and it was live before the end of the month.
To request it raise a ticket along the lines
"From information supplied by the BT Availability Checker I believe ADSL2 is now available on my line.
I'd like to make this change now, please can it be actioned? My router is a TG585v8 which supports ADSL2/2+."
I think I followed the Update Product path through the Help Assistant, probably cancelled the Change Product dialogue when that started and clicked "I'd like to raise a question now".
Keep an eye on closed tickets when the request has been actioned. Once BT accept the order those should give you the change date.
David
Message 4 of 9
(825 Views)
06-12-2011 7:01 PM
Opened a ticket and already got a response with a regrade request, that was fast 10 days till it becomes active isn't it?
Message 5 of 9
(825 Views)
06-12-2011 8:28 PM
That was quick.
It was 5-7 working days when I changed (actually took 7 calendar days), not sure if it is slightly longer now. A day after the regrade order was placed another ticket was added which gave the actual date - in fact two dates, a "commit date" when the work is done at the exchange and a "completion date" 12PM a day later. My change was done mid afternoon on "commit date" with broadband down for under 5 minutes. Sync speed changes then though Plusnet have to do some maintenance on the account (as they phrase it) to enable speeds above 8Mbps. That is normally done when completion is notified.
David
Message 6 of 9
(825 Views)
15-12-2011 10:23 AM
They have now upgraded me to ADSL2+ which is nice of them, can my profile be nudged to match my new speeds please? I think I'm up to 11Mb now.
Message 7 of 9
(825 Views)
15-12-2011 12:51 PM
Message 8 of 9
(825 Views)
15-12-2011 12:52 PM
Thanks Adam
Message 9 of 9
(825 Views)
