Am I on FTTC or ADSL?
- Am I on FTTC or ADSL?
- « Previous
- 1
- 2
- Next »
Re: Am I on FTTC or ADSL?
27-02-2026 11:37 AM
Thanks did this - a lot of dead insects in there! but all the wiring seemed fine. Cleaned up and put back in place - doesnt seem to have made a difference but at least its clean!
Because you are banded, it won't make any immediate difference.
If you post the router stats again, we can see if it had any effect. If it had any effect then the Noise margins will have changed.
27-02-2026 11:42 AM
Thank you for your help - is this what you need? (latest screen shot)
27-02-2026 12:24 PM - edited 27-02-2026 12:25 PM
Line attenuation: 10.9/26.8
Signal attenuation: 10.9/36.5
Yikes! Either a long way from the Openreach cabinet or something dodgy with the cabling somewhere. Do you know how far you are from your local Openreach cabinet?
27-02-2026 12:26 PM
No I dont - but I feel like I need to get my boots on and go on a walk to find out!
27-02-2026 12:33 PM
Yes it is. The noise margins havent changed significantly which means that the faceplate wasnt the cause of the errors.
It sounds like you have a poor line back to the cabinet but getting it investigated and repaired is likely to be difficult as you are meeting the MGALS speed estimates.
27-02-2026 1:37 PM - edited 27-02-2026 1:38 PM
27-02-2026 1:45 PM
@mystreet1 interesting point!. I'm not sure they (OR) would routinely disconnect the E-side pair, but they SHOULD remove the ADSL jumpers at the exchange when upgrading from ADSL to VDSL. If those jumpers are still in place then that will cause problems
- « Previous
- 1
- 2
- Next »
