Am I going to be unhappy ?
- Am I going to be unhappy ?
Re: Am I going to be unhappy ?
20-05-2012 9:49 AM
I'm glad the sync has stayed at 1184, that's one good bit of news.
Let's quickly deal with the audible alarm, just leave it unchecked if you don't want it, if you leave the settings defined then on the Noise Margin plot the Blue line changes to Red when outside the limits. What would you do when the alarm went? Jump More seriously, that depends on which setting has triggered it and what you are doing at the time - On occasions I leave mine running and especially if noise conditions get bad eg. if there is static/lightning about the Noise Margin may go to 0, or a power dip & you lose sync and a resync starts, now under such noisy conditions you can sync at a low speed and lose your high (relative) IP profile from which it takes days to recover on 20CN connections so your download speed is almost as bad as dial-up In such circumstances, unless I've RouterStats on the screen that I can look at immediately, but I also glance at the Lights on the modem/router and if a resync is in process (DSL light flashing) or Red or Power light Red (reboot happening) I have been known to pull the plug on the modem/router to stop the sync occurring but you have to be damn quick.
The Sky box - erm, well apart from the fact that some have been known to chuck out a lot of noise (to ADSL) is it connected to your phone line and if so is it connected via a filter?
Did you manage to get the Sample rate to 8 seconds OK?
Can you post a graph or graphs of any of the Noise Margin fluctuations especially evening/overnight?
20-05-2012 10:02 AM
plus 2 readings since PC startup this morning. All very settled but looking for improvement as you know.
Cheers for now
20-05-2012 10:47 AM
If you maximise the Noise Margin window (before minimising to tray) or just going to do whatever in other windows, then when it does a Capture it will be a maximised image so detail will be more visible.
As regards the variations - as dusk approaches background noise levels tend to increase due to increased atmospheric propagation of LW-MW radio frequencies which cover the same frequencies as Broadband, so you will see a decline in the Margin and increased fluctuations in the noise margin level (sometimes this can also occur in daytime due to atmospheric changes). How much variation will depend upon cable quality, how well balanced the line is, as well as how far from the exchange and whether overhead or underground.
Yours from yesterday evening looked OK as far as it went. If you can leave it running this evening (and perhaps all night?) certainly as late as you can - mid-nightish sort of thing - we'll have a much better idea of what your line is inherently like at the moment.
The current level is good and shows there could be some scope for further improvement if things remain stable. What we don't want is large spikes and jumps in the Noise Margin that is indicative of a problem.
On the Bit loading tab, have you got a nice looking graph with lots of vertical lines where those on the left are one colour, and the larger portion on the right is another? If so, a nice screengrab, again full screen, (I don't know if you can save it on that setup) and posted would be quite handy.
You didn't mention about your mains supply, whether you tend to get spikes , dips and cuts on a frequent basis, a problem some rural supplies suffer.
20-05-2012 5:02 PM
20-05-2012 6:00 PM
20-05-2012 7:32 PM
To ejs : No I cannot confirm if the AOL Netgear router is definitely locked, I just could not get connected to plusnet by simply entering the Plusnet address and my user name, and have no other idea as to what info I would additionally have to add. Any advice.?..I did ask PN via a tech ticket but I dont think the response was as complete as necessary. I would like to try it but at present reluctant to disconnect my PN router considering i am now into the 3rd day of stabilisation/testing and am seriously looking to get an improvement on the current transfer rate, which started this whole thread/post off.
20-05-2012 7:39 PM
20-05-2012 7:42 PM
I am glad to see that we are seeing at least some improvement on your service. Your line is still in it's training period now since I performed an SNR Reset so we need to keep an eye on this over the next week or so. I'll be keeping a close on this for you.
20-05-2012 7:58 PM
If you need the rest of the connection settings, besides your plusnet login + password, they are:
PPPoA
VC-BASED
VPI=0
VCI=38
20-05-2012 8:17 PM
How's the Noise Margin looking jjaycee1?
Edit: for some reason I missed the earlier post
Because your line is in training, and your sync speed is above 1152kbps, it's picked up the 1Mbps profile already, good news, lets' hope things stay stable.
20-05-2012 8:32 PM
21-05-2012 2:55 PM
Anotherone: The filter is in the main phone socket direct, no extensions. The lead is the default length as supplied by PN and same as previous ISP supplied.
Did another BT speedtest this morning and was happy to find that it was IP 1mbps and DL was 0.93. However just done another one at 2.45pm and see that it is back to IP 0.75 and DL 0.69 .... bummer !!
Would I be correct in thinking that it may well rise again due to the current testing period. I was understandably getting to a point of "almost" satisfaction as the better speedtest was allowing me to d/l at 130KB/s transfer speed, but now I am back to 95KB/s. The connection seemed fine and stable at 1mbps so I do not understand why it has deteriorated. Any ideas?
I just need to reiterate how much I appreciate your, ejs and of course Chris' assistance to date. I was hoping to conclude, but looks like I need to wait further!
21-05-2012 3:03 PM
21-05-2012 3:23 PM
Have a listen to your phone line as well - if need be run the quiet line test on 17070 option 2, but I suspect as with previous information it will be fine.
21-05-2012 3:32 PM
