Am I doing something wrong?
- Am I doing something wrong?
30-12-2013 7:01 PM
Ok, so here the issue.
I have a ps3 in my conservatory, connected wirelessly.
Since the plusnet fibre has been installed the internet connection on the ps3 has severely dropped in speed. 08/0.4
I have set dmz on the router for its IP address. And the distance from the router is about 3m only with 2 walls, one wooden one brick.
However before I switched from sky DSL. I was getting 14/0.5
Another thing I find strange is when I do a speed test in there from any other wireless device I get at least 35/15?
Any suggestions will be greatly appreciated.
Message 1 of 5
(1,044 Views)
4 REPLIES 4
Re: Am I doing something wrong?
30-12-2013 7:41 PM
is there anyway to see signal strengh on your ps3?
Message 2 of 5
(589 Views)
30-12-2013 7:56 PM
yeah, it says 78%
Message 3 of 5
(589 Views)
30-12-2013 8:30 PM
You tried moving your ps3 next to the router or even hardwiring it? If its a different router than the one you tried with Sky it may ave a weak wifi signal.
Message 4 of 5
(589 Views)
31-12-2013 5:03 AM
This may not be of any help but........after I was upgraded to ADSL2+ recently I was struggling to get more than 6.5Mbps wirelessly even tho' I was measuring 16.5Mbps via ethernet cable.
Found that my TP-Link router was set for "b/g or n". Since I only had one device equipped with an "n" wireless adapter I changed the default in the router settings to "b/g" -Hey Presto -wireless connections as fast as ethernet on all devices!!!
No idea why it worked but......
Message 5 of 5
(589 Views)
