Am I being throttled?
- Am I being throttled?
05-04-2012 12:32 PM
Ive had a few problems over the last couple of months with my connection dropping out and then coming back on again. I could deal with this as its not like Im always on the comp. Anyways, recently my speed (usually 6.5mbps - 7mbps) has dropped drastically down to about 1.2mb (whereas before I was getting download speeds of 700kbps, Im currently only getting 100kbps ). I used to have no probs watching vids on youtube or downloading stuff but recently its taking ages even buffering a film on youtube. My wife uses the iPad to watch vids and its so bad for watching vids now Its the same with me on my laptop. I used to be able to stream HD stuff no probs, especially as I have the PRO add on. I was under the impression that the Pro addon does not suffer with throttling etc. Any help would be greatly appreciated. Cheers.
These are the results from the bt speed test:
1. Best Effort Test:
Download Speed : 1 Mbps
Message 1 of 6
(1,413 Views)
5 REPLIES 5
Re: Am I being throttled?
05-04-2012 1:27 PM
http://community.plus.net/forum/index.php/topic,96155.0.html if you want help
Message 2 of 6
(605 Views)
05-04-2012 1:34 PM
@gunnerkes,
Do check that link that Jim's provided there but I can tell from an initial look at things it sounds like the issue with speeds could be due to the disconnections you've been experiencing.
Message 3 of 6
(605 Views)
06-04-2012 12:44 AM
Ive gone to that link and done all the tests using the test socket but still Im stuck with a very rubbish connection. Its a bit confusing as my ping is currently at 35ms but then my actual dl speed is 0.56mbps... That is a proper rubbish dl speed considering I pay for the Pro add on with Broadband Extra package 😕 I also checked the current line speed and these are the results :
Telephone number:
Phone exchange:
HONINGTON
Estimated line speed:
7Mb (Accurate to within +/- 1Mbit) - Checked on 2012-02-22 15:07:47
Current line speed:
6.5 Mb
Its really annoying me now, hopefully someone can help
Telephone number:
Phone exchange:
HONINGTON
Current line speed:
6.5 Mb
Message 4 of 6
(605 Views)
06-04-2012 1:15 AM
And what are your router stats? You need to post those here to provide information for other users to comment.
David
Message 5 of 6
(605 Views)
10-04-2012 11:13 AM
Hi gunnerkes,
I've just tried to run some tests but currently you are not connected. Is this something you are aware of?
Jojo
Jojo
Message 6 of 6
(605 Views)
