Am I being slowed down
Bromder
Since moving into my property over a year ago I have from every broadband supplier been told my estimated speeds are 2.0 - 7.0 mbps, before joining plusnet I have on average for the last year always been around 5.0 sometimes went above when they were being really nice and hardly ever dropped below, unless a major fault on line as in once i was connected by tin wire at the exchange not copper and certainly not fibre that would involve spending money by BT.
My concern at the moment after various mistakes in getting my line transferred to plusnet is that I now sit at speeds exactly around 3.5 mbps download I have kept a close eye on this over the last three days checking speeds in the morning around 6.30am when I log on, midday and in the evening my speeds never change. Surely  traffic management is not being used on myself permanently?
Fixes: 162
Re: Am I being slowed down
Traffic management cannot alter the speed your line is connected to the exchange at.
At the moment your line is synced at 4128, which as you are on 20CN gives a profile of 3500
I have noticed that the SNR target is a little higher than ideal, so I've reset your line which puts it back to the 10 day training period and should help improve the speed a bit.
 Chris Parr
 Plusnet Staff
nightstalk3r
Quote from: Chris
But it can alter the allowed throughput, as it's becoming quite clear you are doing with my connection.
Fixes: 162
No, we're not. We don't apply rate limits to the current products.
 Chris Parr
 Plusnet Staff
Bromder
Evening Chris
Many thanks for the reply, and your support, my speed is now back to what it has been for the last year, I am really concerned by your words "training period" what is this exactly and what happens during the next 10 days? Also what happens after the training period?
Can you also please put a note on my account for future reference that I joined plusnet on the 21/09/15 and as of 24/10/15 my line seams to only just made it back to normal (depending on the training period).
Regards
