Am I banded?
Luzern
Seasoned Pro
Am I banded?
Quite recently I had a lot of problems with my computer and the power to both computer and router may have been on and off without disconnecting. My sync is 6650, close to top of 3328kb/s - 6656kb/s band.
All is now well with my system, the hard drive having been replaced.
If I am banded, can the banding be removed? Please!
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Am I banded?
Hi lucerne,
Yes, the line is banded - I'm just removing it now for you. I'll post back once sorted for you.
Chris Pettitt
Cloud Environments Engineer
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Am I banded?
That's been sorted out for you and speed profile updated too.
Chris Pettitt
Luzern
Seasoned Pro
Re: Am I banded?
Thanks fir the quick response, Chris! Speed is up and interleave depth down from 288 to 32.
