Always use the same IP address
radioplus
I've got a Raspberry Pi setup and attached using Ethernet to my Technicolor TG582n FTTC Router.
I've got the 'Always use the same IP address' option ticked in the router settings, however this setting only seems to last for 2-3 days before a new IP address is assigned.
The same thing happened when it was using a wireless adaptor, so I tried using Ethernet to see if that helped, but it hasn't.
Any ideas?
Fixes: 62
Re: Always use the same IP address
the obvious thing to check although I have no idea why or how it could change
Is the device ID the same
TORPC
Would this be better placed in Raspberry Pi chat ?Huh
Fixes: 154
Nope, it's related to the router giving out DHCP addresses.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 154
I too have a raspberry pi set to keep the same ip address and even on restart of the router it has kept it as have my other devices.
VileReynard
Seasoned Pro
Fixes: 9
The router uses the MAC address on the ethernet card as an identifier.
So you need to make a connection and tell it that this MAC address retains the same connection.
