Alternative router to Technicolor?
glreeves
I have a BT HH3.  Would this work with Plusnet in place of the Technicolor router?  I was led to believe when I signed up that it wouldn't.  If not, I also have a Netgear router.  I want to check if my slow BB speed is due to the router.  Can anyone advise please?  Thanks.
Fixes: 154
Re: Alternative router to Technicolor?
Yes the HH3 will work with PN
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
glreeves
Thanks for the advice.
So I was charged for a Technicolor router that I didn't actually need!? grrr
You would only have been charged for postage, not the router itself.
Here's how to get your HH3 working with your Plusnet connection.
http://community.plus.net/library/hardware/using-a-bt-homehub-3-or-2-on-plusnet-adsl-or-fttc/
