Alternative modem only to Plusnet supplied Fibre Router
- Alternative modem only to Plusnet supplied Fibre R...
13-02-2014 8:45 AM
Hello all,
FTTC has finally arrived in surburban LIverpool and I am signed up to switch from my previous generation Plusnet's ADSL service to its shiny FTTC.
I have an existing dual WAN Draytek router ie non ADSL, that I use with various modems to run two internet feeds.
I can of course (with a bit of messing around) configure the Plusnet supplied Fibre Router to sit in front of my Dual WAN router, but I would prefer to use a modem.
BT used to supply then with their installs.
Additionally I would like to be able to monitor the actual line stats via any modem (ie have access to)
Any suggestions for third party products etc - dont mind flashing firmware provided it is reasonably straight forward.
Cheers
Alan
Cheers
Alan
Message 1 of 7
(2,962 Views)
6 REPLIES 6
Re: Alternative modem only to Plusnet supplied Fibre Router
13-02-2014 9:01 AM
With FTTC you get a modem and a router, so you should be fine just to plug your Draytek into the modem.
The PN supplied router isn't an all in one, that's only the BT HomeHub5
Message 2 of 7
(720 Views)
13-02-2014 9:20 AM
Doh - that will teach me to jump to conclusions.
Thanks that is good news - does anyone know if it is it readily "flashable" or possibly safer to source one already done from Flebay ?
Message 3 of 7
(720 Views)
13-02-2014 10:05 AM
Quote from: dragon306 BT used to supply then with their installs.
Plusnet still use the OpenReach install. You will get an OpenReach supplied modem and a Plusnet supplied router. Which of the two OpenReach modems you get is pot luck.
Message 4 of 7
(720 Views)
13-02-2014 10:12 AM
Pot luck? I thought it was determined by the equipment in the CAB, i.e. ECI modem for ECI cab kit.
Message 5 of 7
(720 Views)
13-02-2014 10:14 AM
I've seen a post somewhere that suggests that may not still be the case.
Message 6 of 7
(720 Views)
13-02-2014 10:21 AM
It changed some time last year.
Initially, they were being match to the DSLAM. Now, it's whatever the engineer has in his van.
Message 7 of 7
(720 Views)
