Alternative Broadband speed checker (No flash)
MatrixRob
For those of you who do not use adobe flash player aka the numerous security, vulnerability flaws etc..
there is an alternative..
Below is the link for the speed check:
http://www.broadband.co.uk/broadband-speed-test/
This is the best alternative I have found on the interweb for the UK  Wink
No problem can be solved from the same level of consciousness that created it.
Albert Einstein
