For those of you who do not use adobe flash player aka the numerous security, vulnerability flaws etc..
there is an alternative..
Below is the link for the speed check:
http://www.broadband.co.uk/broadband-speed-test/This is the best alternative I have found on the interweb for the UK
No problem can be solved from the same level of consciousness that created it.
Albert Einstein
