Almost un usable in the evenings
- Almost un usable in the evenings
19-01-2014 8:52 PM
I'll try and attach the speedtests but does anyone have any idea what is causing this?
Cheers
Mark
Re: Almost un usable in the evenings
19-01-2014 9:01 PM
Also, has your internal wiring (that is, from the BT master socket to the router/PC) been changed recently?
19-01-2014 9:05 PM
19-01-2014 9:20 PM
http://community.plus.net/forum/index.php/topic,122054.0.html
19-01-2014 9:53 PM
: HALE MSAN 301 : DEGRADED SERVICE - Tideswell Exchange. The report says the problem was fixed but it looks a bit suspicious to me.
19-01-2014 10:00 PM
dick:quote
19-01-2014 10:18 PM
19-01-2014 10:58 PM
Quote from: englishrick I think it is happening to all of us mate, I'm on Fibre and like you say come the evening (PEAK TIME) it goes down to 1.5Mb - 7Mb, that's from 70-75Mb (OFF PEAK) Here's my thread
It's not happening to me, just noticed latency spikes during peak hours.
20-01-2014 6:42 AM
20-01-2014 9:14 AM
The slowdowns in the evening aren't due to exchange issues or a fault on your line. You're on an old product and have exceeded the usage allowance, hence being restricted between 4pm and Midnight.
Your usage will reset on your next billing date, however I'd strongly suggest taking a look at the products we currently offer as they are much more likely to be suited to your needs and may save you some money.
20-01-2014 9:17 AM
20-01-2014 9:22 AM
20-01-2014 8:26 PM
So a big well done to the tech support guys. Many thanks
