Almost constant dropouts
Bethwoo
Speed has never been great, will be going back to EE if I can’t get this fixed. For the past week or so My internet is dropping out every few minutes, sometimes only connecting for ten seconds before it happens again.
il be in the middle of a call or tutorial and get the message that I’m not connected to the internet.
I mainly use an iPad but it’s even worse on my MacBook.
Tried resetting router, forgetting network and rejoining but still happens.
can anyone help?
Fixes: 62
Re: Almost constant dropouts
I  assume that the dropout is only between the router and the devices not the router losing connection to the internet
If so, and I assume that you are connecting  wirelessly in both cases you could try this https://community.plus.net/t5/My-Router/Constantly-Being-Dropped-on-iPads-and-iPhones/m-p/1487424
Bethwoo
Thank you so much. Hoping I’ve done this properly!
Im disabled so internet is a lifeline for me Smiley
thanks again Smiley
Fixes: 76
How are things looking now?
I've just checked your line from here and everything looks fine so I'm wondering if this was a WiFi issue.
 Adam Walker
Bethwoo
Worked beautifully! No lost connection since. Thank you ever so much.
Fixes: 76
Glad to see this!
Do give us a shout if that becomes a problem again.
 Adam Walker
