All time low speeds tonight.
longedge
I've hit my all time low speeds just now on Thinkbroadband  Sad
A typical daytime result for me would be
Is there any other explanation to consistently low speeds in the evening than undersupply of bandwidth in my locality?
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: All time low speeds tonight.
Hi longedge,
I'm sorry to hear of the speed issues you're having :/
I can't see any issues reported specifically at your exchange. Does this happen often? Just at peak times?
Chris Pettitt
Cloud Environments Engineer
Fixes: 10
Is that using a wired or a wireless connection to the router?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
longedge
Quote from: Chris
I've been aware for a while of a big slowdown, evenings and Sunday afternoons but it hasn't really bothered me a deal as my connection normally remains adequate. I usually get 15-20 Mbps during the day (just got 15.93) and down to around 8-10  at worst in the evenings. Last night however it was just unusable at 0.8Mbps.
I'm using a laptop wirelessly and I'm fully aware of the downside to this. I have however done tests with my desktop which is connected via ethernet and to be honest there was little or no difference in recorded speeds. Although there are a number of wifi networks in my locality, I'm the only one currently using channel 3.
Plusnet Staff
Plusnet Staff
Fixes: 5
I think it's going to be worth raising a fault so that our Faults Team can have a look at a potential congestion issue.
Chris Pettitt
longedge
Quote from: Chris
By my raising a ticket?
Before doing so, I will speaki with my next door neighbour who is with BT. I'll get him to do a few speed checks over a few days to see what sort of results he gets - would that be a good idea?
Plusnet Staff
Plusnet Staff
Fixes: 5
That would give you a good indication as to whether or not it's a peak time issue or not - so that's a really good idea.
To raise a fault, you can do this at http://faults.plus.net
Chris Pettitt
longedge
OK thanks for that - I shall do that.
