turn on suggestions
All the usual things...
- All the usual things...
25-02-2016 6:01 PM
...intermittently noisy phone line, rising noise margin, dropping ADSL speed.
Plus now, every time I start the Plusnet TG582n router, the ADSL connects OK but I have to 'manually' start the Internet connection rather than this starting automatically. Anyone know what the solution is? (To the failure to automatically connect to the Internet)
TIA.
TIA.
Re: All the usual things...
25-02-2016 6:15 PM
If you have a noisy phone line, you need to start there and get it reported, so someone can have a look and get it fixed. Once that's quiet and reliamble, it would be on to the other issues if they still exist.
25-02-2016 7:19 PM
If at all possible I would very much like to have my line reset. Thank you.
25-02-2016 7:24 PM
no chance until you get the noisy line sorted out as it will just go back to horrible after the reset
25-02-2016 11:34 PM
Hello there. I would recommend first plugging your phone & router into your test socket and if the noise continues to persist, we would need to book a line engineer to investigate the fault as this would likely be the underlying issue to any faults with the broadband.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
Anoush Mortazavi Plusnet Staff |
