All-in-one modem/router for Fibre
- Re: All-in-one modem/router for Fibre
18-03-2014 11:22 AM
I've just moved on from adsl to unlimited fibre, and want an all-in-one solution, if its possible.
I have at my disposal a Billion 7800DXL and a Fritz!box 7390. Are any of these capable pf replacing the BT openreach modem?
TIA
TIA
Message 1 of 9
(2,420 Views)
8 REPLIES 8
18-03-2014 11:28 AM
The Fritz!box 7390 should work as a replacement for the Openreach modem.
Message 2 of 9
(782 Views)
18-03-2014 11:42 AM
Ok, thanks. So, just to clarify, I can replace the supplied openreach modem, and supplied plusnet router with just this Frizt!box?
If so how would one cable it up, and I would presume certain settings would need to be changed?
I take it then that the billion would not work, as a stand-alone modem/router?
TIA
TIA
Message 3 of 9
(782 Views)
18-03-2014 12:32 PM
I've been using a Fritz!Box 7390 for well over a year now on Plusnet FTTC without the BT modem (that's stored away safely just in case it's ever needed).
I've posted instructions somewhere on here previously but I can advise if anyone needs help with this device. The main thing with any third party modem-router on FTTC is o set the VLAN id to 101.
Cabling-wise, the F!B comes with a special 'splitter cable' as it has both Telephone and DSL functions, there are versions with different cables - the proper UK version has the exact cable required to simply connect to the telephone and DSL sockets on the FTTC faceplate, other versions are supplied with (or require) adapters.
Call me 'w23'
Message 4 of 9
(782 Views)
18-03-2014 2:57 PM
Fritz!Box it is then. Had a look on the AVM site and listed in the latest firmware update, is this, "Ready for vectoring", which is interesting.
Message 5 of 9
(782 Views)
18-03-2014 3:56 PM
Currently on firmware 'Fritz!OS 06.03', has both 'G.Inp' and 'G.Vector' enabled, just waiting 'til BT Openreach decide to enable either at their end (if they ever do).
Call me 'w23'
Message 6 of 9
(782 Views)
18-03-2014 3:58 PM
I have a static ip address from PN, where does one input that into the FB ? I've looked, but cannot see where it goes!
Message 7 of 9
(782 Views)
18-03-2014 4:00 PM
You don't
The IP is 'Static' at PN's end, as far as the F!B (or any other router you might connect) it's still treated the same as a dynamic address (it just happens that PN always allocate the same address).
[Edit] If it helps, here's my old post on connecting the F!B7390 to PN FTTC (VDSL): http://community.plus.net/forum/index.php/topic,113332.msg974413.html#msg974413 the firmware has been update since that post but the connection procedure is the same (I don't think it 'forgets' the PPPoE setting any more though).
Call me 'w23'
Message 8 of 9
(782 Views)
19-03-2014 10:49 AM
Aha! Ta very much.
Message 9 of 9
(782 Views)
