After upgrade to higher speed but still got the same speed
- After upgrade to higher speed but still got the sa...
19-05-2023 9:33 AM
My renewal new faster speed should start today 19-May-2023 but "speed test" shows the broadband is only running the same speed as before.
Many thanks.
Message 1 of 3
(1,004 Views)
2 REPLIES 2
Re: After upgrade to higher speed but still got the same speed
19-05-2023 12:08 PM
The switch may not take effect until midnight on the appointed day. If not, I suggest you give them a ring tomorrow.
Mike
Message 2 of 3
(969 Views)
20-05-2023 4:14 PM
Hi @kensfishbar
It looks like the upgrade isn't due to complete until the 25th
You should see the faster speeds from then
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
Message 3 of 3
(912 Views)
