Advice wanted setting up Broadband
- Advice wanted setting up Broadband
- « Previous
- 1
- 2
- Next »
Re: Advice wanted setting up Broadband
20-10-2008 3:19 PM
Its location is illustrated in the guide here http://support.dell.com/support/edocs/systems/dim5150/multlang/APCC_CCC/HG689cc1.pdf
Item #3
20-10-2008 3:31 PM
According to the (US) Dell site, the 5150 comes with an integrated 10/100Mbps ethernet connection as standard, which is part of the motherboard rather than an option provided by a NIC card to a PCI slot.
James_G got there first whilst I was looking for a link to post - must type faster, must get a faster computer and a faster connection
20-10-2008 3:34 PM
My internet is fairly rapid though.
My typing is OK, my correction of mistyped wirds [sic] is somewhat better.
20-10-2008 4:00 PM
So sorry to have got you all at it. My PC is in a very awkward place and it is very difficult to get to the back properly without taking all the cables apart. Yes there is an ethernet connection there. Not easy to see whilst peering over the back at an awkward angle !! Well that does make things simpler !! Before someone else says it " what a stupid woman " !!
I would still be grateful about advice on setting up for downloading at night.
20-10-2008 4:11 PM
Quote from: James_G I've bought a few hundred Dells over the years, and I have to say - I've never come across one that doesn't have an onboard NIC.
Obviously not been buying them that long then, or only business models.
However, as far as I can recall every model (domestic or business) sold within the last 3 or 4 years has a NIC on the motherboard.
The Dimension 5150 has "Networking: Integrated 10/100 Ethernet."
20-10-2008 4:28 PM
22-10-2008 10:27 AM
22-10-2008 2:54 PM
Quote from: HPsauce Obviously not been buying them that long then, or only business models.
Not so long - only since 1999, however you are right, only business models.
22-10-2008 5:58 PM
My main problem at the moment is that I upgraded my Antivirus and Spyware programme to version 6 of Spyware Doctor from version 5 about 3 weeks ago. When I came to run the initial smart update after downloading the new version, it was so large a download that I just havn't been able to sucessfully download it on my Dial Up connection at all. After several goes at it of several hours it just timed out or some of the data was lost. As I havn't done a smart update for 3 weeks now, I expect it will be quite a large download now. I suppose once I have got my Broadband connection sorted out, I could get up early in the morning and download it all so that it doesn't affect my monthly limit on OPTION 1. I don't leave my computer in hibernation, I always turn it off at the mains at night, so I suppose it is not much good for the updates to be scheduled at night anyway unless I leave it on. I have found the Automatic Updates in the Control Panel and read the advice about Setting them up now !! Should be connected up soon just waiting for some cables to arrive.
22-10-2008 8:37 PM
go to support section then choose the model number to make sure your runing all the latest drivers for your computer.
puddy
22-10-2008 9:27 PM
so you can set the antispy program to download at 12:15 and pc to shut down at 2am no need to keep unsociable hours, like getting up at 6am
23-10-2008 12:54 PM
It sounds a good idea to be able to time the computer to shut down at a certain time after updating everything, however
I am not sure how to write a ' Shutdown Script ' to add to the Scheduled Tasks. I don't think I have anything in the scheduled Tasks, I just try to remember to do routine maintenance regularly anyway. Perhapes someone could give me some idea how to write a ' Shutdown Script ' .
Thanks for all the help so far
- « Previous
- 1
- 2
- Next »
