Advice setting up TalkTalk essentials router (d-link DSL-3780) on Plusnet please
- Advice setting up TalkTalk essentials router (d-li...
27-02-2015 1:45 PM
Hi
Have just moved over to Plusnet and, in a bout of penny pinching have opted to use the above router rather than get one from Plusnet but I seem to be having some problems getting connected. I have managed to login into the router (by typing in the http//number and admin admin etc) A d-link control panel is displayed with some red and green tick/crosses etc. The wifi is green but internet connection in red - I gues the first thing to ask is the router locked to Taltalk? if not what do I need to do
Your gratefully
Ben
Your gratefully
Ben
Message 1 of 4
(2,087 Views)
3 REPLIES 3
Re: Advice setting up TalkTalk essentials router (d-link DSL-3780) on Plusnet please
27-02-2015 1:47 PM
It might be but the first thing to try is a hard reset
Message 2 of 4
(1,030 Views)
27-02-2015 1:53 PM
Some TalkTalk routers aren't locked. Once you've logged in to the router is there a page called 'DSL settings' or similar? If so try entering your plusnet connection details in to that page.
Message 3 of 4
(1,030 Views)
27-02-2015 1:57 PM
Or your account could be set wrong on our side
I've fixed that now, can you try connecting again.
Message 4 of 4
(1,030 Views)
